Garanti/service 4 år 80.00km eller ubegrænset km ? | Tesla Forum
mousten
mousten Nov 15 '15
Påtænker at købe en Tesla fra 2015. Enten en 85D eller P85). Jeg kan ikke gennemskue hvad der gælder mht garanti. Nogen steder står der 4år på bilen og "motor",samt 8 år på batteri. Nogke steder står der så "ubegrænset km". Har dette noget med årgangen at gøre eller det som evt blev aftalt da bilen blev købt ? Hvordan tilsikrer jeg at have "ubegrænset km" når jeg køber en brugt Tesla ?
Bianco Nov 15 '15
Du skal selvfølgelig have det på skrift fra Tesla, men 4 år "bumper to bumper" og 8 år uanset km-tal for batteri og driveunit (=motor, gear og inverter).
TeslaFreak
TeslaFreak Nov 15 '15
Som bianco skriver
Det er 4 år/80.000 på hele bilen 8 år ubegrænset på Batteri og driveunit
Warranty Coverage
This New Vehicle Limited Warranty includes the Basic Vehicle Limited Warranty, the Supplemental Restraint System (“SRS”) Limited Warranty, and the Battery and Drive Unit Limited Warranty, each as described below. Subject to the exclusions and limitations described in this New Vehicle Limited Warranty, such repair or parts replacement will be performed without cost to you by Tesla when Tesla is notified of the covered defect within the applicable warranty period. Repairs will be performed using new or remanufactured parts at the sole discretion of Tesla. All replaced parts or other components are the exclusive property of Tesla unless otherwise provided under your local law.
Subject to separate coverage for certain parts and the exclusions and limitations described in this New Vehicle Limited Warranty and any minimum period which may be required by your local law, the Basic Vehicle Limited Warranty covers the repair or replacement necessary to correct defects in the materials or workmanship of any parts manufactured or supplied by Tesla that occur under normal use for a period of 4 years or 80,000 km (50,000 miles), whichever comes first.
Supplemental Restraint System Limited Warranty
Subject to the exclusions and limitations described in this New Vehicle Limited Warranty and any minimum period which may be required by your local law, the SRS Limited Warranty covers the repair or replacement necessary to correct defects in the materials or workmanship of the vehicle’s seat belts or air bag system manufactured or supplied by Tesla that occur under normal use for a period of 5 years or 100,000 km (60,000 miles), whichever comes first. Battery and Drive Unit Limited Warranty The Model S lithium-ion battery (the “Battery”) and Drive Unit are extremely sophisticated powertrain components designed to withstand extreme driving conditions. You can rest easy knowing that Tesla’s state-of-the-art Battery and Drive Unit are backed by this
which covers the repair or replacement of any malfunctioning or defective Battery or Drive Unit, subject to the limitations described below. If your Battery or Drive Unit requires warranty service, Tesla will repair the unit, or replace it with a factory reconditioned unit. When replacing a Battery, Tesla will ensure that the energy capacity of the replacement Battery is at least equal to that of the original Battery before the failure occurred. To provide you with even more assurance, this Battery and Drive Unit Limited Warranty will also cover damage to your vehicle from a Battery fire even if it is the result of driver error. (Coverage will not extend to damage that had already been sustained before a Battery fire occurred, or to any damage if the Battery fire occurred after your vehicle had already been totaled.) Your vehicle’s Battery and Drive Unit are covered under this Battery and Drive Unit Limited Warranty for a period of 8 years or for the number of km/miles specified below for your Battery configuration, whichever comes first:
• 60 kWh - 200,000 km (125,000 miles)
• 85 kWh - unlimited miles/km
Despite the breadth of this warranty, damage resulting from intentional actions (including intentionally abusing or destroying your vehicle or ignoring active vehicle warnings), a collision or accident (excluding from Battery fires as specified above), or the servicing or opening of the Battery or Drive Unit by non-Tesla personnel, is not covered under this Battery and Drive Unit Limited Warranty. Warranty Warranty 39   In addition, the Drive Unit is subject to the exclusions and limitations described in this New Vehicle Limited Warranty. Damage to the Battery resulting from the following activities is also not covered under this Battery and Drive Unit Limited Warranty:
• Physically damaging the Battery, or intentionally attempting, either by physical means, programming, or other methods, to extend (other than as specified in your owner documentation) or reduce the life of the Battery; • Exposing the Battery to direct flame (excluding from Battery fires as specified above); or, Flooding of the Battery.
The Battery, like all lithium-ion batteries, will experience gradual energy or power loss with time and use. Loss of Battery energy or power over time or due to or resulting from Battery usage, is NOT covered under this Battery and Drive Unit Limited Warranty. See your owner documentation for important information on how to maximize the life and capacity of the Battery.
Forummets indlæg er redigeret af TeslaFreak Nov 15 '15
mousten
mousten Nov 15 '15
Tak for svar...
