Jeg har samme problem. Har også på skrift fra 2015 at vi kan lade 270 km på 30 minutter. Det kan jeg slet ikke mere. Er ved at samle faktiske tal for det.
Efter klage til Tesla fik jeg dette svar:
Vehicle remote inspection performed due to complain of slow supercharging speed. Conclusion: Logs investigated according to provided timestamp. No hardware issue is detected by vehicle battery monitor system. As vehicle, pack and cells in the pack ages and cumulates charge/drive cycles, it expectedly accumulates some wear, Thus, it is expected to see some slight alterations in performance from the HV battery similarly to other components of the vehicle. Just like all parts of the vehicles, Hv battery and its cells wear similarly to everything else from seats, to gearbox, to drive unit, to interior trim. As the HV battery pack ages and accumulates charge and discharge cycles, it becomes slightly less capable of reaching performance levels it was able to when new. Wear over time makes the battery cells unable to accept as much
fast-charging power as they once did. With a recent software update, Tesla has updated the charge profile in the battery management system of some vehicles which can lead to a slight reduction of fast charging peak power.This update helps further protect the battery and improve battery longevity.
Jeg er ved at læse Rasmussen vs Tesla Class action.
https://www.classaction.org/...en-v-tesla-inc_1.pdf
Der står mange fine ting.
Har også fundet denne der minder om:
https://www.bilklage.dk/...tet/14030%20kode.pdf
