Indtil da er her lidt læsning: Ditec er en traditionel med god forsegler der ligger sig oven på lakken - opticoat er en coating der krydslinker med overfladen og gør den hårdere med tiden.
The first significant difference is the chemistry. The manufacturer of Opti-Coat was a formulator of urethane clear coats for OEM automotive finishes. Dr Ghodoussi explains in technical terms:
"Opti-Coat is a pre-polymer that cross links and forms a continuous film on the surfaces it is applied to, similar to a single component isocyanate that forms a clear coat finish. Opti-Coat also reacts with the substrate that it is applied to so it will not delaminate"
"As far as the durability, it is similar to urethane clear coats. It will not wash away or break down, however, you can polish it over time ! The hardness starts at 6-7 but will increase over time to 9H as it is exposed to heat. Opti-Coat has better chemical resistance, scratch & mar resistance, and release properties than any automotive coating in use."
Translated so we can all understand that - Opti-Coat is not a wax, nano or polymer sealant that will degrade over short periods of time. Or a paint protection product that requires a special "soft wash" or pH neutral shampoo to remain on the surface for any extended period of time. It is a permanent, clear coat finish very similar to your factory clear coat, only harder, and with higher resistance to chemical etching.
The second significant difference is the thickness of the coating. A single layer of Opti-Coat measures approximately 2 microns in thickness. Or 100 times thicker than your typical wax or sealant measuring in at 0.02 microns.
What this means to your vehicle is that any damage inflicted on the surface is absorbed by the Optimum Coating. This is particularly significant in relation to scratches and swirls in the paintwork that inevitably build up over time. Not only will the Opti-Coat resist damage far better than factory finishes, but the coating itself can eventually be removed and reapplied. Preserving your factory coating, and restoring the vehicle to "better than new" condition.
Do I need any special pH neutral car wash to maintain Opti-Coat?
Absolutely not. Opti-Coat is not affected by even harsh chemicals let alone any strong car wash or cleaners.
Be aware of products that claim "up to x amount of years protection" based on washing only with special pH neutral washes. If the protection requires a soft wash to maintain its durability, how can it really be expected to protect your cars finish when it's most needed?
